Dual Ball detects
  • Dual Ball detects
    I first want to say I have been dealing with Brunswick and their technicians for over a month now and they have been great but when the problem persists this long i need to find other solutions to the problems now. Brunswick has a 90 day warranty on electronic exchange so to insure the warranty does not pass we install the electronics as soon as we get them from the manufacturer. When installed the dual ball detects seem to malfunction on a pretty regular basis. The malfunction that normally occurs will be no score or the machine will reset on its own. I have installed temporary walls to insure the reflector is the only thing reflecting the beam, i have cut a small hole in a lid and fastened it to the reflector to insure the beam is directly in the center of the reflector(overspray they call it), I have moved the dual ball detects to multiple lanes to insure failure is with the ball detect and not the installer(lol) or the lane itself. All suggestions and installations of tools have failed, but the kicker is when the orginal dual ball detect is reinstalled the problems vanish. I have brunsick pro lanes, a 2.5 diameter reflector and molex cable that is attached to the unit, and are installed under the ball sweeps
    I understand that this may occur once in awhile, but this is not a one time thing or even a 10 time thing, they have on record over 15 units being exchanged. I do not understand where the problem starts or fixes itself but most units check ok when recieved by manufacturer. I am sure that some may not want to post on topics that others may be watching but any other ideas or thoughts would be greatly appreciated. If you need more info send me a message
    Having fun yet
    Brunswick has 3 or 4 different versions of the time delay module the cycle detect plugs into.
    So far, I've not heard of a mismatch between the detector versions and the time delay versions, but i would not rule it out.
    Of course, the scoring ball detect half of these units would seem to be more straight forward as the input for ball detect hasn't changed since 79 scanners.
    Being under the downsweep, the only thing I can think of that could affect both detect and machine trigger is the adjusting screws being so tight, the vibration of pins hitting the kickback would affect them more than if the spring on the adjusting screw was less compressed.
    We ALL want to keep abreast of how this issue gets resolved. Please keep us posted.
      Bother
      I was never a fan of multipliable ways of reseting a machines
      With that being sad
      Well lets see 1 ball detacher , 2 time delay Miguel , 3 computer trigging , 4 the machine itsalf
      Try eliminating all but one == Chack the timeing between 1-4 /\
      most times all 4 listed will try to do it at the same time
        Are you talking about dual ball detects? 2 small modules on a bracket- or dual output ball detects- one larger brown box with 4 molex connectors on the rear?
        41 years and still learning....
        [email protected]
          Just a thought...how high is the ball detect from the actual lane surface. I have found ball detects that are too high or too low tend to miss fast moving bowling balls. Could this be an issue with your setup?
            as far as height goes the ball detects are at the middle of the ball height , therefore insuring balls trigger the beams. yes it is the brown dual ball detects
            Having fun yet
              3.5 inches to be exact, had to check to make sure
              Having fun yet
                and yes i will keep you guys posted
                Having fun yet
                  If i can get a video of what i see, would this help? I am not sure if this will occur when i am capturing video!
                  Having fun yet
                    I am interested in your problem also! I have the same ball detects with Brun Elec triggering and have had some of the same issues.
                    Dave
                    When I die bury my balls next to the old bag!
                      Yes...post a video as that should help us point you in the right direction.
                        The ball detect should have a small green light on it, when a ball passes the light goes out and then comes back on; I would suggest watching the activity of the light as someone is bowling, if it is working properly probably look elsewhere for the problem. Also, I have seen the detector units move within the mounting bracket, you adjust and then vibration moves it out of adjustment. Check this closely!
                        Just some thoughts, hope you can run down the problem
                          Ok so here is some more info for you guys to chew on. We had asked Brunswick if we could remove the faulty sensor from the dual ball detect.
                          They had no issue with this so we have removed the faulty side and replaced it with another sensor from another ball detect and the problem
                          has vanished again.
                          Having fun yet
