Basically if I adjust the deck cable where the geneva rollers are straight across, the #1 and #5 pins will not release properly causing them to be moved by the spotting fingers.
If I lengthen the cable to the point where the pins will shift while in the scissors, it will set those pins correctly as well as the others.
I have already swapped out deck roller and spotting fingers to eliminate that as a possibility.
I have also replaced all the deck cables. But may do them again.
Just seems like the moving deck is not retracting enough.
I need about 1/8"
I'm open for suggestions.
