2-1 teardown
  • 2-1 teardown
    I had the bolts that hold the deck lift hook cam shear off. I removed the 2-1 but don't know where to have the gear pulled so that I can pull the plate so that I can get the broken bolts out of the eccentric. I've gone to 2 automotive repair shops, 1 machine shop, and tried to buy a 12 ton gear puller(didn' work. Can't get the arms of the puller bahind the gear). What now?
    Will your puller jaws go behind the small gear, it makes the gear easier to pull, owing to less distorsion of gear.
    I have seen the gear actually bow from pulling on the larger diameter. Just a thought. You can also remove the two cover to bearing bolts and slide the cover on the bearing thus giving yourself more room.
    rfm
      No, the jaws of the puller are too long and even if they were short enough are too thick to get behind the pully.
        Also, I thought about sliding the cover, but it still won't give me enough room to get the broken bolts out, as they are broken below the surface of the eccentric.
          Webee, you remove them by going from the other side, just make certain you center punch them exactly in the center or use a 17/64" bit slightly run into bolts to establish true centering. Usually bolts will back out before drilling all the way thru. By removing bearing bolts you gain enough room for an allen wrench.
          rfm
            Ah, gotcha Roscoe. I will try that. Thank you!
              Thank you SO much for the advice, Roscoe. Worked perfectly!
