clutch cam oil seal replacement >>>>
  • clutch cam oil seal replacement >>>>
    what is the proper method of changing the oil seal on the clutch cam on the 4:1 ?
    LOTO
    I personally remove the cross conveyor at this point but you can try this without doing that. It takes about 10 minutes to remove the cross conveyor and will give you so much room to work...you will thank yourself later.
    Drain the oil in the gear box.
    Remove cam.
    Remove spacer that is behind the cam.
    You can remove the O-ring if you like to prevent accidental damage from any tools you might use.
    Using a seal removal tool, place the sharp end in between the seal and the 4:1 shaft.
    You should now be able to pry it out. Here is a pic of a seal remover similar to what I use.
    You may need to pry a couple of times in different locations but the seal should come right out.
    To install the new one...find a socket that will fit the metal outer cover of the new seal. It should also be large enough to fit over the 4:1 shaft...but if it fits the seal, that should not be an issue.
    Align the new seal, place your socket over the metal section of the seal and tap the new seal into the 2:1 housing. Be sure you keep the seal square to the housing and drive it in until the outer metal part of the seal is flush with the housing.
    Put O-ring back on if you removed it earlier.
    Place spacer back over O-ring and inside seal. (Lube lightly with gear oil before installing)
    Install cam
    Replace cross conveyor.
    Fill gear box back up.
    This is how I do this. I usually replace the cross conveyor with a rebuilt/painted one that I would have made up before starting this project.
      Draining the oil is good practise, however not required for this procedure. In fact the two to one can be removed without draining the oil.
      rfm
        Be careful when you reinstall the cam. IT can be installed 180 out.
          When I typed this up...I actually had that draining the oil is optional...but I changed that as from time to time...gear boxes can be overfilled. Draining the oil would prevent spillage if it was overfilled. Roscoe is correct...draining should not be needed...but I certainly wouldn't want to say you didn't need to do it and have a mess later...
            Personally, I would drain the oil. The old oil may contain metal filings, which could cause additional wear on the gears and bearings. Flushing the gearbox and refilling with clean oil would keep the gearbox clean and well lubricated.
            And with poor record keeping, you don't know how long the old oil has been in the gearbox.
