60-1 vs 27-1
  • 60-1 vs 27-1
    out of curiosity, which gearbox version was built with 27-1 gear and worm? reason i ask is one of our centers is getting used a-2's 6 machines are converted A's serial # in the 32k range which should be 60-1, the other 2 have yokes and are 100k serial numbers. i just dont want to stock the extra parts if i dont have too. any help is appriciated.
    Mike
    27:1's started at serial number 109000. That does not mean that you won't find 60:1 setups on 109000 and later nor does it mean that you wouldn't find 27:1 setups on earlier machines. If you are worried about keeping those parts on hand...change them from 27:1 to the 60:1 setup. Requires a new motor pulley, worm wheel and worm shaft. To check if you have the 27:1 on your new machines, look at the pulley on the motors. If both sheaves are the same size...3"...then you have the 27:1 setup. If the pulleys look like the others in your center...you should have 60:1 setups.
      Also the 27/1 machines went back to lowering links.
      70's MP/PBL/LBS,Q-Score
      Prolane Walker sport
        steve they all have the model a motor pully. i thought they would have the 60-1, just wanted to make sure.
          Sounds like they are all what you want.
