winding geneva pulley
  • winding geneva pulley
    I had a helper thought he knew what he was doing and took both geneva plates off, I was never shown how to wind it back. Which direction? How much wind does it need?
    If cables are stall on just replace the plates
    If not 1.1/2 turns should do the trick
      Pardon the intrusion but I kept hearing the phrase 'geneva plate' or 'geneva wheel' and was curious being an AMF mech. I'm assuming it has to do with this mechanical device? Never heard of it but very interesting. Didn't get much chance to really dig into Brunswicks now that Adam Davis is gone from the biz but eventually would like to really see the guts of them.
      http://en.wikipedia.org/wiki/Geneva_drive
        Is it clockwise or counter clockwise. He changed moving deck cable and took off both plates to check the rollers, because he said it wasnt shifting properly.
          The geneva "wheel" is a pulley, located on the left (7 pin) side of the deck assembly, and is, essentially, a cam follower. The cam(s) are the geneva plates.
          The geneva plates are located on both sides of the deck, and are connected by the torsion shaft. Wound around the torsion shaft is a torsion spring. The geneva plates are, aso, connected to the moving deck assembly.
          What happens is this: located on the gearbox is a cam that operates once per cycle. This cam has two purposes, depending on the ball cycle. First, through a cam follower, it closes and opens the scissors, and; second, through another cam follower, operates the moving deck. The scissor cam follower is connected by a link that runs to a pulley (located on the "bastard shaft") that, when it rotates, operates a cable which (again through linkage) closes and opens the scissors.
          The other cam follower operates, through cables, the moving deck. Basically, the cam follower relaxes the cable; however, tension is provided by the torsion spring. The torsion spring forces the moving deck to the rear through the geneva plates, thus opening the deck and allowing it to spot ten pins to the lane.
          Both of the 1 to 1 cam followers are controlled by a blocking finger (which some guys call a "flag") which gets its signal from the detector; which, in turn, gets its signal from the height of the deck above the lane during its cycle.
          I know that this explanation isn't perfect; but it should give you some idea of what happens during a pinsetter's cycle. Steve, I hope that it answers your question.
            The Geneva Drive for the Brunswick pinsetter uses two rollers to produce the movement. The rollers are located just off center of the pulley. Here is a picture of the rollers and the plate on one side.
            In this setup...the shaft with the rollers will rotate clockwise as you see it to move the moving deck to the rear. After half a revolution, each of the rollers will be in one slot each. During the next half revolution, the moving deck will move further to the rear. The Geneva drive refers to the pin riding in a slot...much like the rollers here riding in the slot.
            Hope that makes more sense and helps in understanding the use of the "Geneva" term.
              Thank you both. I read that wiki article that described the concept of a geneva wheel and its neat to see how its been used in this application.
                Riverside:
                Not to rechange the topic but, the spring is wound clockwise if you are looking straight on at the 7 side rollers
                rfm
                  Thank you Roscoe and Wepauls!
