question reguarding ice cubes...
Was lookin thru our parts catalogs and came across the plug in style motor start relay 12-862203-000. now is this for American machines only or is it universal? If not i can just go the grainger routeIs the breaker off? Yes. I grab the wire.. Its hot.... I grabbed him. He bounced... I love 220 voltsTags: None
The new product from Brunswick is an excellent part and will work in any make of the Brunswick A/A-2/Jetback. It is completely universal. There is a setup you can use from Grainger if you wanted to go that route...either is a great upgrade to the electrical system.TSM & TSM Training Development
I have not seen the instructions but I am quite sure there are instructions that will allow them to be installed into a Japanese machine. If there are no instructions for it...get back with us and we will guide you through the install. Very simple to do.TSM & TSM Training Development
well i finally got the relay and the instructions are for american standard and universal.... i tried to make sense of it but there are wires in my boxes that are not labeled and im confused on the jumper as well...... so i drew a pretty lil picture of our contact and then made up a list of connections.. the relay i went with is the one from Brunswick.
here is our current wiring set up and its the same all across the house
coil A- wired to cannon plug for accellerator
coil B- wired to ts-2 and jumped to conn #3
conn #1- wire H-1 to tranformer
wire #7 to ts-1 H
conn #2- wire #33 to thermal overload
conn #3- jumped to coil B
conn #4- wired to #14 on time delay
wired to ts2-1
jumped to conn # 5
conn #5- jumped to conn # 4
conn # 6- is wired to a 3 pin cannon plug called MC-3.. we do not use this connection...
the new relay has connections numbered 1-11 how would i hook this bad boy up? remember the picture is of our current setup.Attached FilesIs the breaker off? Yes. I grab the wire.. Its hot.... I grabbed him. He bounced... I love 220 volts
Originally posted by Sparky8302 View Postcoil A- wired to cannon plug for accellerator
Originally posted by Sparky8302 View Postcoil B- wired to ts-2 and jumped to conn #3
Originally posted by Sparky8302 View Postconn #1- wire H-1 to tranformer
wire #7 to ts-1 H
Originally posted by Sparky8302 View Postconn #2- wire #33 to thermal overload
Originally posted by Sparky8302 View Postconn #3- jumped to coil B
Originally posted by Sparky8302 View Postconn #4- wired to #14 on time delay
wired to ts2-1
jumped to conn # 5
Originally posted by Sparky8302 View Postconn #5- jumped to conn # 4
Originally posted by Sparky8302 View Postconn # 6- is wired to a 3 pin cannon plug called MC-3.. we do not use this connection...
Originally posted by Sparky8302 View Postthe new relay has connections numbered 1-11 how would i hook this bad boy up? remember the picture is of our current setup.Last edited by Steve Stafford (JBEES); 07-22-2012, 05:40 PM.TSM & TSM Training Development
Found what I was looking for...
A of your old relay goes to 10 of the new relay
B of your old relay goes to 11 of the new relay
1 of the old relay goes to 7 of the new relay
2 of the old relay goes to 4 of the new relay
3 of the old relay goes to 6 of the new relay
4 of the old relay goes to 9 of the new relay
13 and 14 of the old relay are still no longer needed so eliminate those wires.Last edited by Steve Stafford (JBEES); 07-22-2012, 06:40 PM.TSM & TSM Training Development
