How many had this happen to them??
  • How many had this happen to them??
    I rebuilt a Turret on a machine yesterday, took basket off, spider, new cluthch facings etc. I put all all back together nice and clean and painted, run machine and while pins enter turret. The Time Delay gear turns for no reason, spoons are not contacting it nothing at all. I find out that the TDG is bad, the blocks are worn and the vibration from the pins entering the turret is causing the torsion latch to open slightly and letting the TDG turn. This machine has been causing the people at this center problems and couldnt catch it, as I have just started here helping a good friend get the machines back in shape. So I put a new TDG and torsion latch in and works good.
    Just didnt know if any of you have seen this?
    Have a great day
    When rebuilding a turret clutch on the bench...you should check the alignment of the torsion latch to the block on the time delay gear along with the condition of the block.
    You should also mark the torsion latch itself in reference to the time delay gear by drawing a line across the torsion latch with the arm and block lined up. This will allow you to know if the arm and block are aligned once in the machine without having to look from underneath.
    You can determine what bumper is needed or if you need to trim the bumper that positions the torsion latch.
    Hope this helps in your future turret clutch rebuilds.
      Thanks Steve, the machine has been blacking out for months due to pins in deck. I finally saws this happen, and the TDgear block was worn.
