Power off Light on
  • Power off Light on
    First ball light on when power off to machine. Just started. Thanks.
    Odds are one of the contacts on the motor start relay is stuck. If you mean its on when pinsetter is unplugged then unplug one pinsetter at a time on that bank of 8 until it goes out and that machine is where you need to look.
    formerly dunsel
      It is plugged in.
        There may just be a wire rubbing the back side of the motor start relay contact actuator keeping it from snapping up when turned off. One of the contact points on the motor start is only for mask lights.
          The top points on relay is for your deck lights.
