Removing bearings from jogger arms
  • Removing bearings from jogger arms
    Any advice on how to remove the bearing from the small end of the jogger arm? I am wanting to replace them with Enviro bearings.
    Use your vise with a large socket on one side and a smaller socket on the other side so that you push the bearing inside the larger socket.
      Same idea with the sockets, but I would use a section of all thread between them, washer and nut on each end, then turn nut on top socket to pull through. Less straining that way.
        Thats the way to go UNLESS YOU HAVE A PULLER
          All-thread with a couple of sockets is a puller. Also, add a couple of fender washers to keep from screwing up the sockets, the all-thread, or the jogger arm.
            I use a press.
            The idea of doing this with sockets and all-thread or a long bolt is how to do this if you do not have a press. Not to knock the vise method though...that too will work but not every center has a vise capable of doing this without damaging the threads on the vise.
            Just a note though...do not use the Enviro to push the old bearing out...you will damage the Enviro. I used to use a new metal bearing to push the old one out and press the new one in all at the same time. Not possible with the Envio's...just find a socket that will fit inside the end of the jogger arm.
              Thinking about my Snap-On socket not fitting the ratchet next time I use it really gets my goat. Invest in an inexpensive press and save yourself time and tools.
              Drill
              David Bolt
              Champaign, IL
              USBC Silver Coach
              IBPSIA BOD
              IBPSIA Advanced
              Technical Certified
              Pro Shops
                dave you do have a nice press. I just ordered one for work today a little bigger than yours. I love this new job....
                  Mine is 50 ton and I have only had 1 item I could not get apart with it at first but after heating was not an issue. Where you at now Eric?
                  Drill
                  David Bolt
                  Champaign, IL
                  USBC Silver Coach
                  IBPSIA BOD
                  IBPSIA Advanced
                  Technical Certified
                  Pro Shops
                    Ahh, Paul Curry's old job, good for you and a very stable job at that.... congrats Eric!
                    Drill
                    David Bolt
                    Champaign, IL
                    USBC Silver Coach
                    IBPSIA BOD
                    IBPSIA Advanced
                    Technical Certified
                    Pro Shops
                      Drill...what couldn't you press with 50 tons?!? Can't imagine anything on our machines holding up to that amount of pressure.
