Time delay module blown
  • Time delay module blown
    I'm having a problem with one of my lanes blowing the time delay module any solutions
    A bit more info may be neaded hear
      I am guessing it happened more than once. Do you know what blew in the module? Does it happen right away?
        It's easy to do if a high voltage wire gets crossed with a low voltage wire.
          It's happened twice but when the reset button is pushed the little black resister I believe it's called blows
            Have you verified that none of the terminal wires have been mixed up?
            You don't need to miss place 19 & 20 to blow components in a TDM as I found out some time ago.
              Yes I checked all wireing and it is right.
                Taylor. Do you have a "take data relay" in your system? If you do you probably have a shorted diode on that board.
                  Yes I do I'll check that thanks
