Machine won't cycle
  • Machine won't cycle
    From my mechanic...our lane #6 will not trigger from any switch...bowl-tronics & 12 strike scoring...Thanks to all.
    "The Man" is now a bunch of thugs
    Please provide some more info so we can help
      If there is a time delay module, I'd start there.
        Excellent place to start! Since the Twelve Strike Scoring by itself does not cycle the pinsetter, this is eliminated. The reset buttons at the ball return and back end, both go directly into the electrical box so that leaves out the Bowltronics. Change the time delay module first. If that doesn't work, check for loss of power to the TD module. Check also for an open circuit in the cord from the wire channel to the cycle solenoid as well as check the solenoid itself. Check voltage at terminals 19 and 20 of the TD module when the machine is on but not cycling. Should show 220vac (plus or minus a few).
        "Efficiency is, doing better what is already being done!"
          Also you may want to check that the cycle solenoid is plugged in on the bottom of the wire channel
          as those plugs can vibrate loose if not locked in properly.
            Be sure the plunger is inserted into the solenoid. Check the lane next to it if you need to see what it should look like.
              Thanks to all for all the replies...was a wire issue and all is well again...we hope...we begin tomorrow night...a great season to all !
