Inner turret ring
  • Inner turret ring
    I had to pull the turret assy off because all 5 bolts for the indexing cam were broken off. Since I haven't been able to get to bolts out(I've tried cutting a slot, heating it and screaming at it, and I still can't get them out), I tried another inner ring, but when I bolt it to the turret frame the spider binds. When I try my other inner ring, it binds when I tighten the seal retainer, then the inner ring binds. I'm pulling my hair out. What am I missing? Do I need to buy the turret ring and the upper and lower bearing rings as a set, or is that a myth? I hope someone can help.
    So when you put the balls back did you leave a space open. If you put too many balls in you could have a bind. Just a thought.
      Yep. I've checked that all 7 times I taken this stupid thing apart. Actually, the initial time I took it apart, there was one bearing missing.
        Yes there should be one bearing missing!
          149 Bearings in the ring.
          B Mechanic Freeway Lanes of Parma
          42 Old Otis A's, Steltronic Scoring, Kegel ION Sport
            Has 149 now, 148 when I first opened it.
              one missing in each set [ inter and outer ] shud have a space about one bearing
                If I have a new turret ring(inner) and used upper and lower bearing rings, could this cause the bind with the inner ring?
                  i am having the exact same issues here. went to rebuild a spider assembly and ive mixed/matched all kinds of parts and i still can't get it to work :/ gave up and rebuilt one from another turret i had yanked out and it works. i'll definitely be keeping an eye on this thread.
                    I can't TELL you how frustrated I am. In all of the turrets I've rebuilt, I've never had this happen.
                      im on my third spider rebuild since I got here we shall see if I have this problem pop up. 4 spare turrets for 10 lanes is over kill but the parts are here so im putting them together
                        The only thing I can think is maybe one or more of the bearing ring set is warped (12-860581). Or the spider ring could be warped.
                          It worked fine with the original turret ring, but as I stated earlier, I can't get any of the broken bolts out. One of them I can grab with vise grips, and still can't get it out.
                            Originally posted by wepauls View Post
                            one missing in each set [ inter and outer ] should have a space about one bearing
                            If by chance i assumed your using [ old + new parts ] is the reason for my [ STATEMENT ]
                            For the most part 149 barrings will work
                              It sounds like it's been thread locked. Heat up the area around the broken studs and try them then. Red thread lock comes loose at about 450 degrees.
