I have a machine that once in a great while all 10 pins will be in the turret and wont fall in, the probe is not contacting blocking fingers or anything. I just have to barely touch the 5 pin in the chute and they all release. Probably need to rebuild the release lever?
pins do not drop sometimes
Hey guys,
I have a machine that once in a great while all 10 pins will be in the turret and wont fall in, the probe is not contacting blocking fingers or anything. I just have to barely touch the 5 pin in the chute and they all release. Probably need to rebuild the release lever?Tags: None
Yeah, I definately would be checking for any bind anywhere in the interlock probe and pin release lever. Bad bearings could cause the problem. Be sure to check the cam follower-type bearing that is on the spider ring. See if it's loose or maybe not rotating properly. Could cause the pin release lever to hang up. And check inside the 5 pin chute to see if there is any lip or whatever that could cause the base of the pin to hang on.It is wiser to find out than suppose.--Mark Twain
Since you said the probe is not touching the blocking fingers I would say you have a bind somewhere in the probe, connecting links, or the pin release lever. Could also be the capture roller for the pin release lever. I would suggest oil and inspect all of these points. Check for binding, something broken or missing or loose.(Psalm 37:29) The righteous themselves will possess the earth, And they will reside forever upon it.
are the blocking fingers all the way up?[email protected] | jsebeny <--YouTube | Cell: 309-275-2453
One more thing to check would be the indexing cam bolt directly opposite the pin release lever. It should be a button head bolt.
If someone has put a normal allen head bolt in there the 5 pin could 'hang up' on it.
Check the very bottom of the five pin chute, where the butt of the pin hits the chute when it is blocked by the lever. If it is dished out and shows cracks then the pin will hang on the edge of the flange that mounts the chute to the ring.
