Gluing a carpet
  • Gluing a carpet
    I need to glue a new carpet onto a pit board. What kind of glue should. I was going to use Weldwood contact cement. Will this hold? Is there something better that I should use? Thanks.
    I've used that glue with all the pit carpets I've ever put on and I think it works GREAT!... I put two coats on the carpet and on the board itself, making sure that the first coat is tacky if not almost dry by the time I apply the second. After the second coat is tacky to the touch, I usually give it a few pokes in different areas just to be sure. I line up the two pieces I'm gluing push out all the bubbles and ripples in the carpet then stack boxes of pins on top if it to apply pressure until the glue sets. I've been told that the pins aren't really needed by other people but I do it just to be safe
    "wiggle that wire see if it does anything"
      http://www.bowltech.com/forums/showt...l=1#post402800
        Thanks Kanga and kyleBB
          I too use the red can of weldwood. The green water-base/nonflammable will not hold up over time. I think most contact cements will work well, just don't use carpet glue! Carpet glue stays soft and the carpet may not stay in place. I have an employee who works with 82-70's at another one of our centers in town, and the first time he saw that it really was a piece of carpet on a piece of plywood, and not a transport band, he was adiment about using carpet glue!
            Thanks for that info, mike. Someone did suggest carpet glue to me and that was why I posed the question on this site.
              Commercial Carpet glue will not hold up to pinsetter usage
                And it doesn't smell as good either !
                  NO GETTING HI WITH THAT STUFF
                    Weldwood contact cement is the best for this application. Red can, not the green one. like others stated, the non-flammable doesnt hold up.
                    i suggest you do this outside, it is flammable and the fumes can lead you in a "altered" state
                      I agree with the red can. I like getting high with this stuff to make carpet replacement more enjoyable... hee hee LOL. Now that's funny, I don't care who you are!!!
                      I always wait until it is Dry to Touch before applying the carpet and board together.
                      "Efficiency is, doing better what is already being done!"
                        Nice to see humor here. I have picked up a can of RED Weldwood contact cement, and will be doing it outside. The high is fun, but the headache afterward sucks....
                          Put glue on half the board and half the carpet. When glue is dry to the touch, line the carpet up on the non glue side and flip the the two glued sides together. Then apply glue to the other sides.
                            I always do it in thirds. Get the carpet lined up where you want it, then clamp 2 corners. That way after you apply the glue all you have to do is flip the carpet into place. No worry about having to pull it up and reposition it if you don't get it quite right the first time. And by doing it in thirds, you don't have as much problem with the glue drying on one part of it and still being wet on another when you put the carpet down.
                              Advil... before you start.. and hey wait a minute.....
