random 5 pin fall
  • random 5 pin fall
    hi, i have a an issue with a deck that will cause the 5 pin to fall over it is very random the deck cables are adj.well and will set pins wor weeks fine then all of a sudden clunk gose the 5 pin any ideas will be helpfull thanks. Mike
    Good work is not cheap and cheap work is not good
    1] deck pad backwoods
    2] lose spotting finger bolt [ missing or brocken ]
    3] look for farad lower cable by rear pulley
      cool thank for the reply i will check those things out right away
        to add to wepauls, check for a bad or missing deck roller as well. the fingers and deck roller work together when spotting pins.
          deck chute, deck roller and scissors... if the scissors are not open wide enough, then they will drag against the side of the pin...
            also if you use those stick on no slide spots, they tend to wear half way on the spot. the pin will lean a bit and sometimes fall.
              If those suggestions don't do it you could swap its chute with another lane. Some chutes can like different lanes.
                You could try using a multi position bucket as a 5 pin bucket. It works well.
                Marty - Pro Bowl West
                56 Jap A-2's Qubica VDB's
                2 Kustodian Walkers
                  thank you all for the ideas, the cable looks good the roller is in good shape and the spotting fingers are cet corectly iam going to swap the deck chute and see if that helps ,and i checked the sissor cable adj. that is set properly so weird i will post after league thanks again mike
                    What could be happening is the pin would momentarily get stuck in the bucket and unstick at the last second and fall. You could use Marty's suggestion by using a multi-chute here. I would recommend the JCP red multi-chute.
                      JCP Pinnacle Deck Chutes are by far the best on the market. when i was still on brunswicks, thats the only chute i ever ordered.
                        Same as House. I only order multi chutes for 5's. Our factory centres had issues with the red 5 pin deck chutes causing falling pins.
                          I wasn't impressed with any version of the 5 pin chute. Only would order Multis, 7+10's, and Ones.
                            Especially the grey's and hard green's.
                              i can think of another kind too, but this company still sells them currently. i will keep it anonymous. but its right up there with the greys and old greens!
