detector problem
  • detector problem
    Hey guys, the strike selection level is staying in the strike postion even at O*. I thought it was the end od the strike controller level, changed it still high. Can can hold it down in postion and it works fine. I came in to it like this was here when it did it the first time.
    I have a spare detector but i want to fix this one. Just can;t seem it figure it out why would it be high instead of in the normal down postion???
    ? LACK OF LUBRICATION COULD TO BE DRY
      fixed for now, the end of the strike selection level was bent up, just didn't see it right off. Never had that happen before!
      Now the question is how did it get bent????
        Shawn check your 1:1 assembly and make sure the allen screws are tight in the gear box.
        Ron
          What is a strike detection level?
          There is no such part in the detector so in order to take a guess at what caused it...we will need to know what part you are referencing.
            I am guessing he meant lever not level.
              Still don't know what exactly he's referring to. Perhaps the pin attached to the head of the strike cam follower?
