I was told there are videos on Bowl Tech on how to change a ball wheel belt on a Brunswick A pinsetter. If so, where do I fine them? |
Changing a ball wheel belt for the first time.
Very visual...if you got pictures...send them too! Thanks!Tags: None
Originally posted by CurtisMcB View PostI was told there are videos on Bowl Tech on how to change a ball wheel belt on a Brunswick A pinsetter. If so, where do I fine them?I'm going fishing and camping!
A little off topic but I guess you could say I cheat a little bit. I use these http://www.grainger.com/Grainger/POW...t-V-Belt-5A547
I used to take off the J bolts...but now I leave them on and take the adjusting bolts out. When I was teaching, I had one guy take the front of the cross conveyor off to get the belt around...I thought that was a bit much but it worked for him.
I think he now takes off the adjusting bolts though.TSM & TSM Training Development
I always did the J bolts because I found that many installs where done incorrectly and the J bolts where not properly seated in the casting. The end of the J bolt has to go into the hole slightly to get the proper grip. Otherwise the J bolt bends, or the casting breaks.
Just something I noticed here and there over the years, and it stuck like mud in my head (amongs't other weird things that get stuck there?).
The original J bolt was a U bolt...but Brunswick changed that. I had a center that still had the original U bolt...and that is when I started dropping the cross conveyor from the adjusting bolts.
The U bolts were far better at holding the cross conveyor in place...still wish they were used.TSM & TSM Training Development
