Low voltage
  • Low voltage
    I have a machine that will not turn at the front desk and will not turn on using the old rocker switches. I know you can
    use a jumper to by pass the old switches to check to see if it will turn .Can someone tell me how to do this?
    Thanks Ron
    Jump between "B" and "C" on the three prong cannon rececptcle
    rfm
      terminials B-C on managers control on pinsetter
        On the 3 prong canon plug you would jumper positions B & C. This in effect closes the front desk switch.
          Will do thanks.
          Ron
            I put the jumper on the b and c and the machine came on.So i assume the problem is from the front counter and the cannon plug?
            Ron
              The last i hurd those switches cost about $ 30.00
              But can be repaired
                I have taken those rocker switches apart and cleaned them up. sometimes the contacts gets gunked up.
                  Go to the junction box that the managers control cable runs to...it should have 8 lanes that terminate in that box. Using the same jumper you used for the cannon plug...touch the jumper ends to the green wire and the white wire for the cable running from the machine that will not turn on. If it goes on...the issue may be at the front desk or in the cable going to the front desk. If it does not go on...you will need to look at the cable going to the machine or inside the cannon plug for a broken wire.
                  Also...what version of AS-80's do you have?
                    I changed the switch and it still does not work.We have source command upgraded to 90's.I will check as Steve suggested and
                    let you know what I found.
                    Ron
                      Steve I checked the junction box and it did not come on I checked the cable like you suggested and found a bare spot near the
                      rabbit ears and will repair it tomorrow morning .Thanks a bunch.
                      Ron
                        You should be good after you repair the cable...if not, give me a call and I can walk you through it.
                          Steve I found three bare spots altogether and all is good.
                          Thanks Ron
