Goast cycleing
Are you sure it's an electrical problem? Because it can be a dashpot adjustment or a groove in the top of the Clutch Actuator Lever (GB90B) I've have a few that I had to file flat because as the Clutch Lever bearing puts pressure on it when it stops, you'll see it move backwards. Then sometimes the vibration or impact will make it trigger.
