Restricted drop link adj
EBN (Ed Fox) has a great adjustable replacement Bracket that replaces 12-350178-000 for the low deck restricted drop. You remove the old bracket altogether and the new one clamps on in a "U"-Bolt style. This is awesome because not only can you adjust it to raise or lower the blocking finger link, but you can also adjust it side to side for perfect alignment."Efficiency is, doing better what is already being done!"
Another option is to remove the bottom bolt of the bracket...loosen the top bolt of the bracket...insert a 1/4" washer between the bracket and the deck lift shaft. Put a bolt back in place so it goes through the washer. This will shim the bottom of the bracket out causing the top of the bracket to rise. Using a spacer on the x-washer pin can cause the restricted drop to pop off of the spacer as the radius of the new spacer will no longer match the radius of the lifting point in the restricted drop.TSM & TSM Training Development
It might also be worth checking that the machine is stopping at 0 and that the deck height adjustment is adequate first.
I usually find what Roscoe is talking about and/or the shoulder bolt and hole is worn. On worn links I've drilled out the hole to accommodate a flanged oilite for the pin release lever. This one was done perhaps 7 years ago, no significant wear to speak of.
dirty turret!! i'll be more than happy to rebuild them for ya for a small fee[email protected] | jsebeny <--YouTube | Cell: 309-275-2453
Originally posted by JohnSebeny View Postdirty turret!! i'll be more than happy to rebuild them for ya for a small fee
Thanks for the offer though!
Originally posted by Steve Stafford (JBEES) View PostYea...but all your indexing linkage fell off.Factory & Converted A-2 (US, Ger, Jap)
Originally posted by eddieg View PostHey guys, if you run out of adj on the LH finger. I put a steel sleeve over the x washer to get more adj. any other ideas?
You run out of adjustment because the bracket on the deck lift shaft bends. I always take the bracket off and reinstall it upside down.(Psalm 37:29) The righteous themselves will possess the earth, And they will reside forever upon it.
