Pit cushion
Time to use brains, not brawn! Couple ratchet straps around cushion up to ball track, you can pull up and swing around and pull out back with 75% less work. My favorite tool,i use them for everything, they make up for lack of strength for an old guy like me!Brent V
Originally posted by yazu View PostIt was welded a few years back.
JMO
Good luck taking it out. Old farts like us and our aching joints don't work so well with these heavy parts."Efficiency is, doing better what is already being done!"
Lonnie...I have welded reinforcement plates onto pit cushions and have seen great results. Some of these plates have been on for about 15 years now with no signs of cracking. Have you tried these? If so...what has been your experience with the longevity of the repair?TSM & TSM Training Development
I did mine a bit at a time...yes it takes time but it won't take that long. Part of the rubber will separate from the cushion but I have seen no real issues from this. I usually use a form fit pit cushion cover after this repair and I think that probably assists the rubber to stay in place.TSM & TSM Training Development
I have one i did many years ago, broke completely vertically right in middle. I sliced the rubber, probably about 5 or 6 inches wide then v'd the crack on backside and ran a heavy bead on it and while hot peeled the rubber out of the front. Cleaned that up and v,d the front and did a small bead on it, then came back with real heavy beads on both sides. Ground the rubber piece off to fit over the weld best i could then reattached the piece i cut out with Devcon. I can hardly believe it, but it is still on and holding good to this day. I have a couple that i put end plates on that have broken loose that i may try the same thing. I have used quite a few of the end plates and overall they work really well.Brent V
Originally posted by Steve Stafford (JBEES) View PostLonnie...I have welded reinforcement plates onto pit cushions and have seen great results. Some of these plates have been on for about 15 years now with no signs of cracking. Have you tried these? If so...what has been your experience with the longevity of the repair?
I guess what I MEANT to say is, if you can't weld and a professional welder is not available or the cost of the plates and a prof-welder would cost more than a new cushion... Go with the New Cushion!
Is that stated better Steve?"Efficiency is, doing better what is already being done!"
LOL...yep, I understand what you were trying to say...and I have seen some of those types of welds you are referring to. Some of them look like my 8 year old would have welded them. Popcorn welds I call them...looks like globs of popcorn stuck on the metal. Prep work is soooo important for a good weld. Many have no idea how to do it properly and the end result might as well have been done with packing tape.
Of course, there is an alternative to a metal pit cushion altogether. Scripps sells a "plastic" pit cushion and although it sounds like it wouldn't work...I have been testing one for Bill for about 4 years now and it is doing just fine. Just an alternative to the heavy pit cushion that so many of us dread to have to pull when something goes wrong.TSM & TSM Training Development
Originally posted by yazu View PostJust found another one with cracks on both ends. I'm to old for this.Brent V
