MIND STUMP
  • MIND STUMP
    I HAVE A-2 AND THE PROBLEM I'M COMING ACROSS IS THE SWEEP AND RAKE ARE COMING DOWN AT THE SAME TIME AND TRYING TO REMEMBER WHAT U HAVE TO DO TO STOP THAT ISSUE IT'S HAVING THE SCORING TO MESS UP AND NOT READ
    do you mean the deck and rake??
      Do you mean rake and deck if so check your shotgun [ mouse, trip, ] linkage from pit cushion for luse bolts missing brocken parts
      call we can walk you thrue ##\/
        YEA THAT'S WHAT I MEAN
          Regardless what scoring you have, it should allow for electronic trigger without quick rake drop like model "A" as well as the normal quick drop. If your deck and rake are coming down at the same time, then your quick rake drop (shotgun) didn't release. Still, if this is the case, it should still score correctly and if the scoring is not reading the pins because of this, then I would check the timing settings on the scoring system for when it is supposed to take the picture and send the data.
          "Efficiency is, doing better what is already being done!"
            sounds like the time delay module. I had a machine do the same thing at my old center. Move the time delay to another machine and see if the problem follows
              If the settings in your scoring are all set, I would check both the clutch adjustment and the timing on your rake cam. If either one of those is out of adjustment, it will affect when the rake comes down as the cycle starts.
              But your shotgun should be releasing either way, so that could need adjusting too.
                Do you have Accuscore, Accuscore II, Accuscore + or Accuscore XL?
