10 pin topples when reset
Hi folks...we have had a recurring issue for awhile of the 10 pin tipping upon being reset...our mechanic is working through a few things moving deck cable wise, but I just thought that I would post here for some additional help...it does seem to be just the 10 pin that is our issue...thanks to all in advance, Dave"The Man" is now a bunch of thugsTags: None
An un-level (bent) scissor arm, worn gripper pads and the condition of the deck pad will play a role.
Which way does it wobble? Front to back or left to right?Factory & Converted A-2 (US, Ger, Jap)
Could be stabilizer bearings. If the bearing moves when the deck is raising, the bottom of the pin will move also. Then when the deck lowers back down, the bottom of the pin will end up in a different position and then when the scissors release and the deck raises again, the pin can wobble...even falling over.TSM & TSM Training Development
Thanks for responses...my mechanic won't be back in until Mon...this an intermittent issue and I think that he is closing in on it...I will show him these suggestions then...thanks again to all, Dave"The Man" is now a bunch of thugs
