Now, I've been trying to get the pins in the center on spot and this lane is a problem it seems. I've had a heck of a time doing this. The other evening I tried to first level the deck with the stabilizer rods. This has been nothing but a pain that I can't seem to figure out. Does anyone have any tips on making this easier. We have A-2s with Scotch Yokes, so I know how to screw in/out the yoke screw but every time I make an adjustment nothing seems to get close to the 15/16ths of deck spotting height.
This is also the lane where the pin deck is too high and the ball jumps at the pins. The buildings foundation moves around alot and is in bad shape. There is lots of vibration with the particular building.
Can you put the deck down on lets say 3 pieces of 1 inch wood (side, side and front) or how about 3 clutch shoes?. Take the rods off, and then properly put them on and then tighten the nuts?
I think I got it closer to being level now but the pin spotting isn't uniformly off on all the pins. The 7 and 8 pins are on spot, while the rest are not. If I move the deck forward isn't it going to move the pins that are on spot now? I took a quick look at the deck and it seems like there isn't too much forward it can slide.
I will attach some photos of what the spotting looks like now.
