Deck problem
Deck problem
Hey guys, all of a sudden once in awhile I will have a machine when there are standing pins. The machine will come down, scissors wont close all the way sweep will sweep pins away and deck comes down as it is setting pins back up for a spare but no pins. This was happening randomly through out the night last night. The deck pads seem bad, was wondering if that could be it also?Tags: None
If the deck is detecting standing pins, the detector rod is OK and doesn't need adjustment.
If the scissors are failing to close, check for loose linkage; or a weak scissor spring. As Bill suggested, a drag link may be binding against something, causing the scissors not to close. Also, a scissor arm may be hung up behind a bumper, preventing the scissors from completely closing.
I just checked my texts from 10 days ago, my night guy sent me a text that he had to fix the 10 pin scissors on that lane. When I get there this afternoon, I am checking that. I was dumb enough not to check his work when he first did it. Ill keep you posted.
Thanks for the replys.
Thanks for the replies guys, well one of the guys working for me worked on this a few weeks ago. I remembered this last night when I was home. Checked my texts from over a weeks ago, and it was the scissor he worked on. The screw was hanging out of the stationary deck today, and the scissor assembly had no spacer or lock washer in it either. So needless to say I forgot to check the work from that time. All up and running now
