push/pull type solenoid for rake trip ...part number
thinking about flipping the mounting bracket for the current solenoid so I can mount a pull type solenoid above the bracket the solenoid contacts/trips .... in my head it will work I will try and do a test pair on friday morning ...ill let u know what happens...incase anyone is wondering ... the rt solenoid recieves signal from sensors in camera....the rake then falls opening a trigger clip on the rake shaft that allows a signal to be sent to the tiume delay mod...then to the cycle solenoid... so if the rake trip solenoid dosnt fire to drop the rake the machine will not cycle ... the machine cycling is kinda important so im kinda looking for an alternative quickly ...the signal is sent to the solenoid via the camera sensors ... i have bowltronics still installed on everylane from the previous scoring system but either way for these to work the rake trip solenoid needs to fireLast edited by jhova; 01-09-2013, 01:46 PM.
You could use a pull style solenoid...using a bolt through plunger end...mount a L shaped link to the bolt and the small end of the L to the angle section you were pushing against. You will need to experiment with the length of the L shaped link. I think it would work...I think it would work better if you had links on both sides of the solenoid but not sure if you will find one with electrical connections in a way that would not interfere with the second L link.
Just a thought...TSM & TSM Training Development
