Machine Breaking 1 to 1
I have a pinsetter that has broken the 1 to 1 twice in the last three or so years. We replaced it about a year and a half ago and found a broken key and a wallowed out keyway along with it. I have now noticed in the last couple of months that the 1 to 1 is jumping again. I am only assuming at this point that it is the same issue with a broken key. So, I am wondering if anyone can steer me in the right direction as to what could be causing it to break multiple times. I had issues with this particular lane breaking the deck lowering hook cam follower in the past, could this be related as the 2 to 1 is driving the 1 to 1 and it could possibly be getting some of the effects of the bind through the gear train?Tags: None
Thats their intent. The spring goes under the boot, large end down, small end wrapped into the small groove in tip where a small snap ring was originally installed which is removed for the spring install. The yellow booted micros already have the assist spring installed from the factory. Both are a must for jam switches.Last edited by Roscoe; 01-20-2013, 02:37 PM.rfm
Hvae you changed your jam tube? If so does the current one have two springs in it or just one. I have seen where if there is only one spring that there's not enough tension on the cable and it can cause it to hop off the perch on the rear of the deck lift shaft. Just a thought
When you've replaced the gear and shaft, has the gear been a press fit?Factory & Converted A-2 (US, Ger, Jap)
I'm with Kanga. I've seen shafts and gears with almost a slip fit. I send 'em back. Even the ones that do fit correctly, I take them to a machine shop and do a light 'spline' style knurl job on them. Helps the key to keep the gear in place.Ray P. McGiveron
If your first fabrication doesn't work-keep adding metal
Be safe when you wrench.
Originally posted by emcnelis View PostI have a pinsetter that has broken the 1 to 1 twice in the last three or so years. We replaced it about a year and a half ago and found a broken key and a wallowed out keyway along with it. I have now noticed in the last couple of months that the 1 to 1 is jumping again. I am only assuming at this point that it is the same issue with a broken key. So, I am wondering if anyone can steer me in the right direction as to what could be causing it to break multiple times. I had issues with this particular lane breaking the deck lowering hook cam follower in the past, could this be related as the 2 to 1 is driving the 1 to 1 and it could possibly be getting some of the effects of the bind through the gear train?(Psalm 37:29) The righteous themselves will possess the earth, And they will reside forever upon it.
We replaced the entire assembly with a brand new one from bowl mart. I did change out the jam tube recently when replacing all 3 deck cables but I just checked and there is indeed 2 springs in there. As for the jam switch boots/springs, I will definitely be looking into ordering some of those. I will also be taking note of all these suggestions for when it comes time to change this guy out again. I know I have some time as its not too bad as of yet. Thanks a lot guys.
Carefully watch the motion of the moving deck when the pinsetter cycles. If it "slams" to the rear, it could be caused by the wrong 1to1 (moving deck/scissor) cam. There are different styles. Each cam is specific to the type of machine.
12-100828-000 for machines with a lowering link
12-102794-000 for machines with a scotch yoke
It's been years since I wrenched on a pinsetter; but, I believe that there was a third moving deck/ scissor cam. It had something to do with the serial number of the pinsetter. I could be off-base on this; and apologize if I am incorrect.
Originally posted by SoCalTom View PostCarefully watch the motion of the moving deck when the pinsetter cycles. If it "slams" to the rear, it could be caused by the wrong 1to1 (moving deck/scissor) cam. There are different styles. Each cam is specific to the type of machine.
Originally posted by emcnelis View PostWe replaced the entire assembly with a brand new one from bowl mart.TSM & TSM Training Development
[QUOTE=Steve Stafford (JBEES}
I do not know anything about Bowl Mart...do they sell rebuilt units or 100% new units?[/QUOTE]Both and some decent prices. http://www.bowl-mart.com/items/pinse...ck-a2/list.htmI'm going fishing and camping!
