Pinsetter launchings pins up lane.
I have a machine that likes to shoot the pins up the lane. Happened three times today. Here's the scenario...second ball is thrown or a strike occurs. Rake sweeps and stops at 180, the deck will shift and drop pins from 0 degree height. Rake comes back forward sending the pins up the lane. Have not been able to figure it out yet, any ideas?If you don't like getting beat...get better.Tags: None
The rake board is most likely getting stuck behind the rear edge of the lane. The safety stop should be checked and adjusted. To prevent that from hapening check that the rake latch is properly adjusted and that it isn't unlatching md cycle.
Originally posted by mikeb View PostThe rake board is most likely getting stuck behind the rear edge of the lane. The safety stop should be checked and adjusted. To prevent that from hapening check that the rake latch is properly adjusted and that it isn't unlatching md cycle.
I agree with Mikeb and Jacko. However, even if the shotgun latch is disengaging, the proper adjustment of the rake lowering stop bracket should prevent this. You can adjusted at 180 degree stop. There should be only a 1/16" gap between the bracket and the "V" lever (aka:Rabbit ears). This bracket is meant to prevent the sweep from dropping behind the tail plank in the event of latch failure."Efficiency is, doing better what is already being done!"
Be sure the top bolt of the rake shock is tight. Too often this bolt will come loose and allow the issue you are seeing start to crop up. Here is an idea that you could do to help keep the issue from occurring in the future.
Zot makes a kit similar to this modification and can be installed quite easily.TSM & TSM Training Development
One of the biggest problems is the upper shock mounting bolt. If it isn't tight enough, it will oval out the mounting holes. At my last center, out of 40 machines, 38 were loose. Some worse than others. This should be inspected at least monthly.
Originally posted by Steve Stafford (JBEES) View PostBe sure the top bolt of the rake shock is tight. Too often this bolt will come loose and allow the issue you are seeing start to crop up. Here is an idea that you could do to help keep the issue from occurring in the future.
Zot makes a kit similar to this modification and can be installed quite easily.I'm going fishing and camping!
Originally posted by PJ View PostMade that bracket our self years ago I think we got the idea from Steve Stafford.
Originally posted by SoCalTom View PostOne of the biggest problems is the upper shock mounting bolt. If it isn't tight enough, it will oval out the mounting holes. At my last center, out of 40 machines, 38 were loose. Some worse than others. This should be inspected at least monthly.Factory & Converted A-2 (US, Ger, Jap)
Thanks for all of the suggestions. I have gone through and checked/adjusted all rake components. So far the machine has worked flawlessly. I did find the stop bracket to be out of adjustment as was my rake crank. Thanks again.If you don't like getting beat...get better.
Originally posted by Kanga View PostI've also seen this on occasion when the incorrect spacer has been installed. They don't notice the spacer is too short, tighten it, the bushing binds, then they back the nut off.
