electrical box questions
I have seen on here that some electrical boxes do not have motor contactors. I have to replace an old Federal Pacific and was wondering what everyones opinions are on what to replace it with and where to get the parts needed to clean up the box.Tags: None
Here is what I use
Looking for DAYTON, Surface Mounted, Open Power Relay? Find it at Grainger.com®. With over one million products and 24/7 customer service we have supplies and solutions for every industry.
There will be some wiring changes you will need to make when changing out that Federal Pacific contactor.
If you need any help post back here.Last edited by drhookmec; 01-26-2013, 06:49 PM.Go with what works and not what the book says.
I have been using a relay from Grainger to replace the motor contactors in the electrical box. It is still considered the "motor contactor" in the box...even though it may not look like one you use. I will try to get an updated picture of one in a box that is in use. I have some pictures of one that I have been trying to build...but I have not gotten much further with it due to issues I have with changing the current wiring diagrams and schematics of the pinsetter. Not sure if I want to change the current design or leave it as is.TSM & TSM Training Development
Originally posted by Steve Stafford (JBEES) View PostNot sure if I want to change the current design or leave it as is.
On second thought, I don't know if Brunswick did it this way, or am I out of my mind. Since the pinsetter runs in sequences, how about the electrical box? There could be a diagram for each of the functions of the electrical box. Such as diagramming where the high voltages come in and are distributed; and another diagram for the safety switches, one for the cross conveyor system, etc. I think that this would make things easier for troubleshooting.
On third thought, I am out of my mind.
Hey Steve! Is this the part number: 1EHX2 Relay and 1FC15 Relay Base for the motor contactor? Did you get the wiring schematic for this and the motor start relay: 1EHW4 Relay/1EZ95 Relay and 1FC14 Relay Base? I just need help with the wiring and appreciate all the help from you and Lonnie!! Thanks, Bruce
This is the contactor I use. I Was able to simplify the HV terminal strip. I also have din rails on the bottom of all my electrical boxes. Mt TDM relay, MSR, and Motor Contactor all mount on the rail as I install them.
Cloth: ShamWow!
Machine: Johnny 5
Originally posted by shamefowjze View PostThis is the contactor I use. I Was able to simplify the HV terminal strip. I also have din rails on the bottom of all my electrical boxes. Mt TDM relay, MSR, and Motor Contactor all mount on the rail as I install them.
http://www.grainger.com/Grainger/wwg...peaheadSearch=DO A NEAT CLEAN JOB, AND FIX IT RIGHT THE FIRST TIME. THE ONLY WAY TO WORK.
Originally posted by MASTERMIKE View PostAnyone have an overload or breaker wired into that?
The overload would be wired in series with the motor's "hot" lead. (Black is hot; white is return; green is chassis (earth) ground.)
Originally posted by batbowler View PostHey Steve! Is this the part number: 1EHX2 Relay and 1FC15 Relay Base for the motor contactor? Did you get the wiring schematic for this and the motor start relay: 1EHW4 Relay/1EZ95 Relay and 1FC14 Relay Base? I just need help with the wiring and appreciate all the help from you and Lonnie!! Thanks, BruceTSM & TSM Training Development
Originally posted by SoCalTom View PostIt shouldn't be too difficult to wire in a breaker or overload if the motor doesn't have one built in.
Was just wondering how it worked with that grainger contactor bud
MikeDO A NEAT CLEAN JOB, AND FIX IT RIGHT THE FIRST TIME. THE ONLY WAY TO WORK.
Mike
I have some mini breakers I was going to mount on the electrical box next to the 1 amp fuse. I think 2 of my 24 motors have overloads and I have no overloads in the electrical boxes. Yeah, something bad is gonna happen before I get to put them in. Thanks for starting this thread and jinxing me.Conditioner: Pantene Pro-V Brunette Expressions with Color Enhancer
Cloth: ShamWow!
Machine: Johnny 5
Originally posted by shamefowjze View PostI have some mini breakers I was going to mount on the electrical box next to the 1 amp fuse. I think 2 of my 24 motors have overloads and I have no overloads in the electrical boxes. Yeah, something bad is gonna happen before I get to put them in. Thanks for starting this thread and jinxing me.DO A NEAT CLEAN JOB, AND FIX IT RIGHT THE FIRST TIME. THE ONLY WAY TO WORK.
The overload situation is the real problem, I doubt that with Federal Pacific contactors that his motor protection is in the electrical box. Thus he will have to add an overload for motor protection. The overload is the costly part.
I use these in my equipment now because they are three phase, but you can see what you need.
http://www.grainger.com/Grainger/SCHNEIDER-ELECTRIC-IEC-Overload-Relay-90130a-3EA10?Pid=search
