Pin setter Motor
Pin setter Motor
Hello everyone. I had someone replace the centrifugal governor in the motor and it runs but once you add any belts it turns at half the capacity. Could it be a capacitor? He also replaced the stationary switch. Any ideas would be greatly appreciatedIf the same thing happens more than once, You got a problemTags: None
Ok so I spoke with my boss today, and I guess the governor has to be placed on a certain spot on the shaft. All is well now and I replaced the capacitors but no luck.If the same thing happens more than once, You got a problem
