first ball strike detects at 270
Originally posted by mccarthym69 View PostHey guys , i have a machine that detects first ball strike at 270 ...... anyt ideas.. i am thinking adjustment is needed on the deck lowering hook (equipped with a scotch yoke) ..
So are you saying the machine is detecting a strike when it should detect standing pins?
If so check your detector rod adjustment.
Also make sure one of the roll pins hasn't broken off the detector rod.
Please describe what you are seeing.
Does the pinsetter lower on 1st ball, detect strike, sweep pins after raising deck, deck lowers to the floor at 270 degrees and sets a new set of pins?TSM & TSM Training Development
Sounds like your deck lowering hook is dropping back down on the lowering pin at 0deg.
If this just started happening then check the end of the scotch yoke for a broken deck height adjusting bolt.
At the end of the scotch yoke there should be something that looks like this...
If the adjusting bolt that holds this part on breaks the deck will drop down causing
what you are seeing, The bolt has a long pin on the end of it that holds that part in place
and what commonly happens is the pin breaks off.
Compare it to another machine to see if it's the same.Go with what works and not what the book says.
Originally posted by mccarthym69 View Postafter a strike on first ball is thrown, rake down, deck to the floor ( not stetting pins), back up , rake sweeps, deck lowers sets new pins.
Bottom line...if the deck lowers to 1 inch at 90 degrees, the deck lowering hook is not engaging the pin in the deck lift shaft ears at 0 degrees. This can be an eccentric adjustment, bad bearing in the scotch yoke, missing block (see drhookmec's pic above) in scotch yoke or bad bearings in the deck lift shaft ears.TSM & TSM Training Development
The deck will look like it is lowering faster as it must travel 7 1/2 more inches in the same amount of time. It still is the issue that the lowering hook is not engaging the pin at 0 degrees. Go to 0 degrees and see if the lowering hook will engage the pin by pushing it down. Also...if you put the detector on 2nd ball...does the deck holding hook engage the pin on the deck post to hold the deck up? This might help narrow down the issue.TSM & TSM Training Development
Originally posted by mccarthym69 View PostYes the deck holding hook will engage.Factory & Converted A-2 (US, Ger, Jap)
