Lift rod mounting shaft broke off
  • Lift rod mounting shaft broke off
    Is this replaceable? If so, how, and what part #?
    http://www.stadiumtenpin.net
    www.********************** I believe they sell a replacement shaft that doesnt require any welding. Just grind the old off.. and install this..
      12-400149 is the shaft - you would have to get the old one out and weld the new one back on. Like speir01 said, I think its pinsetterpartplus that has some kind of bolt on shaft available.
      Marty - Pro Bowl West
      56 Jap A-2's Qubica VDB's
      2 Kustodian Walkers
        The only thing the PPP shaft eliminates is the welding. You still have to cut out the old shaft completely.
          the ppp shaft works very well. just make sure you only grind off the weld to get the broken shaft out. the ppp shaft needs a nice flat surface.
