machine clicking on off
well so far i replaced c.b., moter contact ,relay , time delay unpluged the ball acc. unpluged the masking switch taped the wires to make sure it was not the switch moved the 1st 2nd ball micro away checked thr turret micro sw. the back on off sw. the beck sw . still the machine will flicker i hear it going on and off but so fast it never turns the machine off did turn off the light for a second until i changed all the aqbove i also unplug the light. so what is next ? it only flickers when moving but never in the same place or when the rake movesany help on this one
Tags: None
I am guessing; but, does this happen when the machine is in operation? If yes, I would suspect that the turret jam microswitch is the culprit. The test is to manually press the turret jam microswitch, keeping your fingers clear of all moving parts. Press the switch firmly and see if the issue disappears. Adjust the bolt that contacts the switch, making sure it is positively pressing the microswitch. If this bolt is slightly out of adjustment, it will cause similar issues.
Make sure the fuses are seated properly. I had a machine that flickered and it was the 1 amp fuse cap had loosened and the fuse and cap were just sitting in the fuse holder.Ray P. McGiveron
If your first fabrication doesn't work-keep adding metal
Be safe when you wrench.
Also make sure your turret hanging rods are not bent. The way I check the turret jam switch is, unplug motor, turn machine on, back switch bolt off switch till deck light goes off, turn bolt back on switch till light comes on, then turn bolt an extra turn and a half.I'm going fishing and camping!
