Time delay
  • Time delay
    K.L.
    ABC specs., 3.6 Seconds, from the time a ball pass the head pin until the deck freezes the pins. 2 seconds on dashpot usually will accomplish this timing.
    Roscoe
    rfm
    Re: Time delay
    they have a spec for that? I'm glad they dont check it - I got mine at 5 seconds !
    I need the time, have the old easiscor system that takes a while to score both lanes at the same time. Besides, it helps scoring in my opinion.
      Re: Time delay
      Marty:
      Thats suggested min. To my knowledge no max. is written up. 5 seconds quite common on scoring setups. Indeed it helps averages
      rfm
        Re: Time delay
        We use a 5 sec delay also,after using a pot to determine our desired setting we started using resisitors .We use 150k to obtain our delay.The resistor is easy to change in the time delay module.
        Peanut
        Peanut
          Re: Time delay
          we always get people saying slow rack, slow rack if a pin rolls around late and knocks a pin down for a strike. I tell them I'll see what lanes your on next week and fix those 1st. I just love it when it talks a little longer than normal to cycle and the final one falls just before the deck touchs it.
