tri-plates
Member
- Dec 1998
- 7490
- A2's 82\70Xli's
- Qubica
- kegel Lane Walkers "Edge"
- synthetic Pro Lane & SPL
- 1990
Re: tri-plates
I like the urethane ones on the lift rod side and the steel ones on the other side. I just feel that if one comes loose on the lift rod side the urethane won't tear the ball up.
DrillDrill
David Bolt
Champaign, IL
USBC Silver Coach
IBPSIA BOD
IBPSIA Advanced
Technical Certified
Pro Shops
Re: tri-plates
I like putting the Urethane type on both sides reason being on lift rod side it helps cut down on Balls getting big gouch circles on them when caught on top of cushion and these guards help protect the Bowling pins from scratching up also because they do rise and fall alot and hit the metal guards when they are there and I feel that helps save pinlife somewhat.And from past expeirences it seems the Quality brand are best made over the gray Brunswick style.Part # 12-4036 I think
JohnJohn
Re: tri-plates
HEY LARRY, I PREFER THE VANTAGE WHEEL GAURD BECAUSE YOU CAN PUT THE BOLTS THREW THE HOLES ,ALSO THEY STAY TIGHT AND DONT DAMAGE PINS OR BALLS,THEY WORK GREAT! I HAVE TRIED ALL KINDS AND HAVE HAD THESE ON FOR A FEW YEARS NOW AND HAVNT HAD TO REPLACE ONE YET.DONT USE THE METAL ONES OR THE GREY ONES FROM BRUNSWICK THEY SUCK.Its just a matter of time until something will go wrong.
Members
- Nov 1998
- 585
- Brunswick A/Jetback
- AS80 / 90 Upgrade
- Sanction Standard
- 24' HPL, Wood, HPL Decks
- 1986
Re: tri-plates
I did a test on a plastic about 10 years ago and made my own out of this plastic. The originals are still on the same machine. I beleive the cost back then was $10-$15 to make both sides for one lane. Since then I havn't made my own, but then I havn't needed to!
Tech of the Year 2005,2007
- May 2000
- 16570
- A/A-2, GSX, Sherman, AMF
- Qubica/AMF/Brunswick
- Kegel/AMF/Brunswick
- HPL/SPL, ArmorPlate/Anvil
- 1977
Re: tri-plates
Kurt,
What kind of plastic and where did you get it?
SteveTSM & TSM Training Development
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
