Elevator adjustment
  • Elevator adjustment
    Does anybody out there have an easy way to lower the elevator frame?
    let me be myself
    Re: Elevator adjustment
    Billman:
    I use a split rim tire tool (WHICH HAS A HOOK END ON IT), use it to pry up elevator, insert a maple or any other hardwood wedge, and use an air chisel to cut out washers, one at a time.
    First time with the chisel may be trying, but with a little practice one can usually lower an elevator in ten to fifteen min.
    Don't cut out bottom big washer, its there to clear the square on the carraige bolt.
    Roscoe
    rfm
      Billman:
      Neglected to mention:
      Maintain 1/8 to 3/16" height between a straightedge, resting on carpet and carpet clamping plate, and the ball wheel- best measured with an allen wrench of the chosen size
      Roscoe
      rfm
        Quote:]Originally posted by Midwest Pinsetter Service:
        Billman:
        Roscoe
        [/QUOTE] Roscoe: I'm glad to hear that someone else uses allen wrenches as feeler gauges.
        let me be myself
