pins on floor
  • pins on floor
    how do i stop or slow down the excessive amount of pins that are on the floor behind the machines at the center im at they are mostly out of the turn pan
    james
    Re: pins on floor
    Brunswick makes a particle board shield that goes across the back of the machine that supposed to keep pins inside the pinsetter. Many centers have some version of this shield(mine are homemade) Make sure that your pinwiper and turnpan adjustments are correct as this will reduce the number of pin that are thrown out. Balls can also carry pins up the liftrods high enough to pitch them out the back and onto the floor.
    let me be myself
      Re: pins on floor
      A pin deflector cord will stop most of the pins being carried up by a ball.
        Re: pins on floor
        check your turnpan and pinguide adjustments. also check for worn cross conveyor belts. check top pinwheel guide rollers. also check cross conveyor mirco switch, if out of adjustment pinwheel will not stop as required.
        Ball Returns Shorted Out?
        Trip rocker arm
        Lower ball cushion board
        Backend motor plug
        82/70 combi motors
