pin lights
pin lights
What flourscent light is best to make the pins look the whitest? Thanks for reading.HowardTags: None
Re: pin lights
THE ONLY LIGHT TO USE IN A DECKLIGHT IS A F40DX. THIS IS A DAYLIGHT DELUXE LIGHT AND PROVIDES THE CORRECT COLOR TEMP TO MAKE THE PINS LOOK GOOD. I HAD A MECHANIC PUT REGULAR F40COOL WHITE BULBS IN AND IT TURNED EVERYTHING YELLOW AND WASHED OUT LOOKING. [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
Re: pin lights
Hi Howard,
I agree ! you won't find a flo. tube that makes your pins look any better than the F40DX. Definatley not the cool white or the $1.99 shop light.Macgyver
Tech of the Year 2004,2008
- Jun 1999
- 4204
- A- 2 / 8270
- Qubica / Frameworx
- Phonix-S / Kustodian
- Prolane / HPL / SPL
- 1983
Re: pin lights
I would agree that the daylight deluxe is a good bulb we have used them also,but ran into cold start problems on 104v .We now use F40SP65 from Graingers it is about the same lighting as the daylight series,with no starting problems. Only $3.00 a bulb also.
Hope this helps
PeanutPeanut
Re: pin lights
I stand corrected ! One time I ran out and I could not find replacement flo. tubes locally so I borrowed a F40SP65 from a friend at another center and it worked very nicely as stated by Peanut.
Peanut,
What kind of start problems were you having when you decided to switch? Just curious.
ThanksMacgyver
Re: pin lights
We also use the F40SP65's. They look great, but make sure you use a good ballast. I am having dim lighting problems on lanes with the ballasts you get at the hardware store.(energy savers).
Get the good ones from Graingers or Brunswick.<span style="font-style: italic">Sometimes it is best to use good advice from many individuals to achieve the ultimate result.</span>
Re: pin lights
I'm currently using f40c75 tubes by phillips. these are whiter than previous posts, but they cost $6.00 per tube. With these tubes the pins look newer longer, after 3 yrs of use they still look new from the front. They are guaranteed for 5 yrs. the whitest bulb they make is f40c90. These are really white!!!!!!!!!!!!! thes tubes may need to be ordered from a lighting supply co. They cannot be found in most stores.
Gook Luck!
Re: pin lights
After deregulation of the power companies in Alberta on Jan.1, and seeing our power bill almost triple, we just did a complete retrofit of every flourescent fixture in our center, including the pin lights.
We changed out all of the ballasts and replaced them with Magnatec Triad electronic ballasts, and now use F32T8SP40 bulbs for lane lighting and F32T8SPX50 bulbs for pin lights. This combination draws a lot less power, with about a 30 percent increase in brightness. I havent seen the results in our power bill yet, but they say the savings will pay for the retrofit in about 2 years.
RussYou only need 2 tools...WD40 and Duct Tape. If it doesn't move and it should, use WD40. If it moves and it should't, use the tape.
Tech of the Year 2005,2007
- May 2000
- 16570
- A/A-2, GSX, Sherman, AMF
- Qubica/AMF/Brunswick
- Kegel/AMF/Brunswick
- HPL/SPL, ArmorPlate/Anvil
- 1977
Re: pin lights
russ...do you have the part number for the ballasts?TSM & TSM Training Development
Re: pin lights
jbees:
The ballasts we used are B232I120RH
this ballast will control one or two lamps.
It has a rating of .49 line amps, which is a lot less than the ones we pulled out...some of the older ones were .9 amps and even the energy savers are .61 amps.
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
