fuses
  • fuses
    I need to know the fuse values for Japan built electrical boxes. center fuse and right hand fuse. thank you, digger
    Re: fuses
    Right hand side....for low voltage side of transformer...5amps
    center fuse....for high voltage side of transformer....2amps
    Later
    Peanut
    Peanut
