Ok boys...whats your preferance? When
you change you gearbox oil do you use...
gear oil or regular 10-30 oil?I prefer
gear oil,slows or stops any tiny
leaks.We are changing our gearbox oil
are we not? lol
I use 10-40 in my 20,000's w/the dashpot time delays, believe that the switch to 90w was made when the electronic TD's came out, cause the thick stuff just won't go through the dashpot right.
I use gear oil, as I have no dashpots. Gearoil in my opinion gives the gearbox better protection with less friction between the worm and bronze gear. As for leaks, I installed baby bottles under the gearbox drip pan, if bottle fills 1/2 full in 30 days I check for problem. Bottles are only 4oz. in size. Some other thoughts???
Definately Gear oil. I use a Heavy duty
90/140 made by Dri-Slide. This oil was recommended by BRC and Brunswick many years ago. I havn't seen any more writings on it by Brunswick. But I still use it with no problems. Dri-Slide says that this oil contains Molybdenum Disulfide which tends to settle slightly on the parts.
[This message has been edited by Charles Heuer (edited 01-03-2000).]
That was why I stopped using it. Didn't want to take the chance that internal damage would occur over time. I found some of that stuff that leaked out of a couple of seals and it was almost rock hard.
Kevin
Kevin...I use 80-90W gear oil with dashpots. I have no issues with the oil. I have used it only in the southern states though...Florida, Texas and Arizona.
I see someone revived this old thread. I know we discussed this in a different thread, but when your back room temp is in the 40's or 50's, that 90w turns into jell-o.
My wife originally hails from Lake Placid, NY. Took my nissan (stick shift) up there at christmastime one year. It was -25 (yep, 25 BELOW) out. Went out in the morning, shake the stick to be sure it's in neutral, put clutch in, start engine (thought THAT was a minor miracle, but I digress). Let clutch out, motor STALLS. Had to start it again, tach it up to about 2500 and dump the clutch in NEUTRAL to get the transmission oil (goop) to break free.
I can see how it would never cause problems down south, but up here you'd be playing with needles every 6 months. Easier to run the lighter weight stuff ... although the thick stuff is better from the wear perspective.
90w. gear oil in Texas works well, never tried it with the dashpot however. For the mechs up north do you ever have problems with the rake shocks in cold weather? always wondered.
formerly dunsel
Wow...I guess we have discussed it before that statement. 2000...someone dug for this one... [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img] right Mike? LOL
That is why I mentioned the southern states because I remebered we had discussed this somewhere before...or something. [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
steve, i dug in 250 some odd pages for this thread. just got done changing oil in the boxes and wondered what people used. when you have questions, you search for answers. all hail bowltech! [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
Why use a multigrade oil in the north? There is not enough heat generated in the gear box to bring it up to the 40 weight viscosity. Run a straight weight oil...like 30 or 40 weight.
