Homemade Cross Conveyer pulley guards
  • Homemade Cross Conveyer pulley guards
    I use a old pit curtain and use a ball lift housing assy. as a Template.use a sharp razor knife to cut the circles outta curtain.Then bolt that on to the pulley and use a scissors stop urethane stopper as a guard on the allen bolt on the conveyer.You just have to press the spacer rubber over the allen screw and it actually stays on.
    Re: Homemade Cross Conveyer pulley guards
    Oh by the way the part number for the rubber bushing is 12-2000032 the black urethane ones work better than the reddish softer ones from brunswick
      Nice tip Jim,
      Thanks
      Mike
      Mike Wilson
      Bowl-Tech Inc..
