white nylon deck rollers V/S rubber ones
I have a house full of brunswick white nylon deck rollers and it seems to me that they cause alotta unwanted pin jams.Ive always used the Rubber ones and never expierenced this problem.I used to Pitch them when i came across them,but i have no choice in the matter now because someone else orders all the parts and they think theyre better.Give me some feed back guys...Thanks
------------------Tags: None
Re: white nylon deck rollers V/S rubber ones
Hey Jim
You asked for views and I think the new deck rollers were JUNK when I bought them last year.
I felt the old rubber rollers were WAY more reliable and when they went bad you could just order the rubber roller from Quality bowl and re-use the hub.
Just my 2 cents worth.
Grambo
Bowl-Tech Site Admin
- Nov 1997
- 5652
- Brunswick A, A2
- Brunswick Scoring Systems
- Kegel & A22
- All
- 1979
Going back to the rubber ones myself.
MikeMike Wilson
Bowl-Tech Inc..
Member
- Dec 1998
- 7490
- A2's 82\70Xli's
- Qubica
- kegel Lane Walkers "Edge"
- synthetic Pro Lane & SPL
- 1990
I guess I'm glad I've never heard of them.
DrillDrill
David Bolt
Champaign, IL
USBC Silver Coach
IBPSIA BOD
IBPSIA Advanced
Technical Certified
Pro Shops
We also make deck rollers and it would be great if anyone who has posted here would like to evaluate them. Just call Bill or Jim and we'll get you a handful for free.Murrey deck rollers are a black urethane about the same durometer as our deck chute or slightly softer.A few years back we made them too hard and that created a bounce problem so we softened them up a bit and everyone seems to like them now. We value your feedback and would appreciate a call-800421-1022 or E-mail.Thanks, Jim Galloway
In my opinion, the black rubber rollers are the only way to go. I have tried all types and only the rubber ones last, and won't create deck jams from either freezing on the xpins or causing pins to bounce up and intefere with turret spoons, keeping the spider from locking. Anything but rubber is just asking for problems.
the white urethane ones are garbage but can be modified to work a lil trick i learned from my head mech is to round the edges to match the black ones the sqareness of the edges cause alot of the problems we use our grinder and a pencil to do this good luck
jamesjames
I've got one machine that keeps jamming in #2 chute. The chute seems to be smooth enough, and doesn't seem to be causing the trouble. When the pin drops into the chute, though, it seems to sit at an angle on the roller. (hard to describe, I guess, but if the roller were rotated 90 degrees, the bottom of the pin would slide sideways into position...) The pin seems to be sticking on the roller, it allows the pin to wobble front to back, but not side to side, then when setting, it jams in the chute. I replaced the roller, also, new black rubber. Any thoughts???
Pins are a year old, but rough. Bottoms have been resurfaced to become flat, they're Bruns Max's.
Probably should post a new thread of this, but since we're on the subject already.....Oldsmagnet -- Sidney MT
I just got my free Murray deck rollers in and im well pleased with the quality and texture of them.I put them in a troublesome spot and no jams yet.....Check that#2 pin deck chute out as to what Brandname it is and then check your 2 pin turret wire ajustment so that the pin falls properly into the chute.Also clean the aluminum around the deck roller I call it the half Moon...thats on the stationary deck or scissors deck...Good Luck
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
