installing rod cover
  • installing rod cover
    I would like to know what you guys use to install new rod cover. Please specify what type of cover you use and what is used to make the rubber or urethane cover slide on easier. I have used various things, but curious to what is used out there.
    Re: installing rod cover
    i use an air fitting that i made out of a "lower ball wheel guide roller shaft" the kind that bolts on. i'll give you a part # if you'd like. what i did was this, i welded a female air fitting to the end of the stud. this is the best thing i've used yet. i've tried the Quality air fitting and that thing is a piece of #@*%!!!! anyways use baby powder and lots of air. and if the lift rod covers look like there going to pop.....run like hell.lol. i just takes air, baby powder and some muscle. good luck. shame
    Cloth: ShamWow!
    Machine: Johnny 5
      I use they blue urethane rod covers and they slip right on.
      Drill
      Drill
      David Bolt
      Champaign, IL
      USBC Silver Coach
      IBPSIA BOD
      IBPSIA Advanced
      Technical Certified
      Pro Shops
        I have been using Murrey's rod cover since 9/98 and have found it much better than their previous style. I use a standard air blowing tool and hose clamp it to the lift rod cover. Pour some baby powder into the buisness end of the cover and get it started on the lift rods. Apply some air and begin working it around the top corner. From here if it is on the machine...you will have to musle it. I usually take them off the machine and put them on the floor with them in front of me while I'm sitting in front of them. Apply air and pull the hose toward you. Just keep pulling and you will be surprised how easy it will go on...
        Steve
          I use both the red cover and the original gum rubber. As everyone said use of air is a must. I just use a hose clamp around the cover and clamp to hose. Also I used to use baby powder, work great with original cover but had trouble with the red stuff. Brake fluid works like a champ on both.
            I also use air to install rod cover. Baby powder is a must, but be sure to use a brand name and not the generic type. The off brands contain less talc which is the slip agent. I use both the red and the tan rod cover. I am surprised that know one has call the rod cover by it's nickname yet. I am refering to a part of a horse. lol
            billman
            let me be myself
              I use the red brunswick rod cover ,last much longer then the original white cover.We clean the rod up with cleaner and a green pad
              to make sure all the old rubber is off and then we spray the rods and spray inside the hose with the general purpose cleaner we use,its similiar to 409 that you can buy at the grocery store.With the help of a little air the rods covers will slip on easily and after the cleaner dries it stays tight on the rods so they dont twist or walk up or down the rods as much.They still will sometimes get under the caps but not near as much as when we used powder.Biggest problem is it hard to twist the rod cover if you want to rotate them to balance out the wear on the rod covers.
              [This message has been edited by David Johnson (edited 05-20-2000).]
                LARRY, ARE YOU TRYING TO PUT ON GUM RUBBER OR URETHANE COVERS ? IN THE DAYS I HAD GUM RUBBER IN MY CENTER I PUT THEM ON WITH GOOD OLD BABY POWDER. BUT I WILL LET YOU KNOW I HAVE REPLACED ALL 32 MACHINES WITH RED VANTAGE LIFT ROD COVER AND USED SLICK 50 TO PUT THEM ON WITH. THE FIRST ONE I PUT ON IN DECEMBER OF 96 HAS SHOWN NO WEAR OR TEARING WHATSOEVER.EXCEPT I FOUND IF YOU PUT THEM ON PER THIER INSTUCTIONS THEY SPLIT AT THE CURVES OF THE LIFT RODS,SO I JUST USED ALL THE BALL LIFT ROD CAPS AND I HAVNT HAD ONE OUT OF ALL 32 DONE GIVE ME ANY PROBLEMS.
                Its just a matter of time until something will go wrong.
                  Just make sure when you cut off all the old cover you clean all of the gum off of the metal before attempting to slide new cover on
                  it goes on a hell of a lot easier. I use something strong like acetone or astrolane cleaner, then the old fashioned way of air and baby powder to put them on. Have fun
                    I use the Red covers and jut like every one else... baby poweder and an air compressor. it makes things heaps easyer if you've got an extra set of hands... then you can sit back and hold the air gun while they guide the cover on to the lift rods!!
                    works wonders!! lol
                    Tech
                      Air hose and tire talc. PJ
                        Hi
                        well the center i work at in Sydney Australia we use of course compressed air and also have found that high grade brake fluid works brilliantly the brake fluid dries and doesnt break down the rubber and makes the cover slide on so easily its GREAT oh well u guys may do it different but each to thier own hey fellas byeee
                          I just got one of the new Quality Rod Cover installation tools. Works great (a little pricey though). It is pictured in the "Tool Cabinet" on the front page of Bowltech. I use the Brunswick Red Rubber Rod Cover (say that fast a few times)....
                          JS
                            Years ago, they used to tell us to use dish soap to lube the rods so the cover would slide easier. Geez.... It worked, but would rust the rods and you couldnt turn the covers when they started to wear. We use powder now and built a little fixture with a water type valve and a small nipple that you could hose-clamp the end of the roll to. Also, we built a little stand using a shaft that fits through the hole in the clapper box. it keeps it up off the floor and allows us to spin the lift rod assembly around to make it a little easier. The brake fluid idea sounds interesting. They told us in Brunswick school that brake fluid lubricates rubber....
                            41 years and still learning....
                            lanedoctor@hotmail.com
