Having a real problem with breaking Quality Style cam follower shaft kits across the house.(40 lanes)
Scissors are not to tight, 1 to 1 housings are not loose
Missioned:
Have had good luck using set screw # 11-102220, w/nut and lock washer in place of stud quality uses. Of course, shaft itself must have no groove worn in it ,nor hole in plate enlarged,nor plate to cover bolts loose.
Hope of some help to you
Roscoe
Hey Missioned.
Another thing to check is if the 1-1 mounting plate is bent where the shaft goes through it tends to break that bolt a whole lot more often.
Also check and make sure the deck jam microswitch is working correctly.
I used a large allen wrench to force the x-pin down and made sure the machine turned off immediately.
With the deck cable off the moving deck cam follower should move freely.
Make sure it is not binding on the bushings or hitting the rake cam follower when it is all the forward.
I had 2 machines break the "bitch bolt" in 1 week and found out that a pinchaser was clearing blackouts by pushing in the motor contactor...OUCH
Hope this might help.
Grambo
I have found that using a Grade 5 bolt works better for us. the grade 8 are so hard that if you have any movement at all between shaft and plate it will break.I believe that the Kit studs are grade 8 or at least hardend treated.
Masternut:
Most set screws are grade 12- vast difference from grade 8.
Secret to this problem is, no for and aft shaft movement as cam follower is following cam. No bolt can withstand a plate with an elongated hole. Indeed when rebuilding a 1to1 assembly, I provide an extra 1 inch of support for shaft.
Roscoe
Hey Masternut
I insatalled the collar on all my machines and they worked GREAT!!
Just make sure you get it tight against the mounting plate and extra tighten the bolts.
I bought an extra long allen wrench and was able to put the split collars on easily.
While doing P.M. work I found on different occasions the bolt BROKEN and the collar holding the shaft in place with the machine causing NO problems.
I would suggest investing in the collars because when that shaft falls out it can tear up so many things that the collars pay for themselves in parts and the headaches of changing 1-1"s
Grambo
Yea,I think they are great too, we have them on all our 116 brunswicks,we have only had 2 bolts break since 1985 but it is a releif to know that if one does break the cam follower want get caught up in the cams and damage plate.
Roscoe:how do you add the extra 1" support?
when you go into a 1:1 for someone.
Peanut:
I only change assemblys on an exchange basis, found long ago just replacing covers not really a viable procedure as is does not address all the problems a 1to1 has. I mill the cover at the hole. to ensure alignment,then weld a 1-1/2 od by 13/16 id, 1 inch long, mild steel bushing which incorperates a set screw, to lock shaft. Then finish ream the 13/16 bore ,in the mill to ensure the shaft is perpendicular to gearbox.
I usually carry three such units with me at all times.
Still think you superimposed a hospital picture with your mchs.
Roscoe
