turrat problem
turrat problem
Hey guys,I'm having a problem with a turrat. I have never seen it happen myself, but they trll me that it happens a few times a day. the pinchaser tells me yhat he saw it happen one time and I can't see it myself, but he tells me that once the six pin indexes a pin falls between the space after like the pin gate is not latching. i have recycled the machine for hours and no problems . the other nite when I was bowling it stopped and I went down back and it looked like the spider releast, double index, pins everywhere. I would be grwetful for any suggestions.thanksTags: None
Tech of the Year 2004,2008
- Jun 1999
- 4204
- A- 2 / 8270
- Qubica / Frameworx
- Phonix-S / Kustodian
- Prolane / HPL / SPL
- 1983
Re: turrat problem
Check pin gate first.Sounds like the pin gate is locking after pin instead of in the neck of pin.Before checking adjustment and condtion of strap and roll pin,lock pin gate with hand and let 3 pins line up on cross conveyor-then reach under cross conveyor and lift up on pin gate latch to release pins and watch the operation-the gate should stop each pin until next postion.Then repeat the proceedure let 3 more pin line up then release them.Do this10 or 12 times and you will proberly see it happen.
It is hard to check pin gate by just cycling pinsetter because the pins come up spaced apart.
Hope this helps
PeanutPeanut
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
