cycle solenoids
  • cycle solenoids
    Just a note about non OEM solenoids. I have found the non OEM solenoids are about 50 ohms higher the OEM solenoids. (the rating is labled the same)This means on a 208v machine solenoid may not cycle pinsetter 100% of the time, as they require more voltage to offset the increase in resistance. I had 2 machines with this problem, I checked wiring, time delay modual, and related switches. I installed OEM parts now machines cycles properly. This is just a note for guys with 208v machines that may help.
