kickback plates
  • kickback plates
    what is the best adhesive to use in conjunction with nails to replace a kickback plate?
    Cloth: ShamWow!
    Machine: Johnny 5
    Re: kickback plates
    For me i have found that...WELDWOOD contact cement is great on it.Even thin coat on plate and kickback,let dry and carefully align then stick it on.Works great on kickers too,they never come off until you peel it off.Just my 2 cents worth.
      Re: kickback plates
      works for me. make sure back of kick back is ruffed up before applying glue.(use coarse sandpaper.)
        Re: kickback plates
        Weldwood contact cement gets my vote!!
        let me be myself
