Ball Wheel Belt
Members
- Mar 2000
- 784
- A-2,Amf,GSX
- Frameworx
- Kegal phoenix-s and A-22
- Brunswick Pro anville
- 1971
Re: Ball Wheel Belt
The spliced belts are designed to be used only as a temporary fix when the endless belt breaks.If you use them for that purpose
and then put on a endless when time permits
they work fine.
Re: Ball Wheel Belt
David nailed that one, takes 5 minutes to put the spliced one on for temp fix during a league, but they will not last as a "permanent" belt.
Must add, though, that they are no substitute for inspecting ball wheel belt condition during quarterly maintenance, and changing them out BEFORE they break.
I keep two on the wall, just in case, had to use one once in 9 years, saved my butt that night, had a regular endless on the machine the next afternoon.
Kevin
Re: Ball Wheel Belt
All that goes without even mentioning the fact, there is a $115.00 difference is price between the two
Roscoerfm
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
