Pit mounts
  • Pit mounts
    Just wondering what type of pit mounts everybody is using. I have a mixture of different types of urethane mounts and was just wondering what you "super-techs" use on your babies. (Please, no Heisenburg compensators) LOL
    let me be myself
    Re: Pit mounts
    I use alotta red Brunswick santoprene mounts and they last along time, but ive tried Qualitys the hard light green ones they seem good too and most companys mounts are long lastu=ing thats one thing they all didnt screw up.I also have the original 3 part mounts sortta like old refrigerator mounts theyre good too but pain in ??? to change at times.
    John
    [This message has been edited by Larry (edited 05-28-2000).]
    John
      Re: Pit mounts
      I use the old metal ones, I like them cause you can just replace the rubber mounts when they go bad. Makes more sense to me rather than replacing the whole mount. I got some pretty cool rubber mounts from Grainger that are slightly taller and just as tough. I have been using these on the front to elevate the pitboard slightly and improve pin flow. Works pretty good, if anyone is interested I can get the Grainger part#
      jerrid
        Re: Pit mounts
        I use some of the traditional rubber mounts and some urethane, usually the vantage ones.
          Re: Pit mounts
          I have always favored the traditional style as well, but my current center has lots of the red santoprene mounts, They hold up very well. I cant remember the last time I ordered any.
          Mike
          Mike Wilson
          Bowl-Tech Inc..
            Re: Pit mounts
            I HAVE USED BRUNSWICK SANTOPRENE MOUNTS IN THE PAST, AND WHAT I FIND IS THAT THE STEAL SPACER TENDS TO EGG-OUT THE INSIDE OF THE HOLES, THUS, CAUSING A SLIGHT TICKING NOISE AND THE SPACER NO LONGER FITS TIGHT IN THE HOLE. NOW, I USED THE OLD BLACK RUBBER ONES IN ALL MY PITS, AND THEY SEEM TO LAST, PLUS THEY ARE A LOT CHEAPER THAN THE SANTOPRENE MOUNTS. JUST AN OBSERVATION.
              Re: Pit mounts
              Personally, I like the green urethane ones that quality sells, they've been pretty bullet-proof in here
              Kevin
                Re: Pit mounts
                We redesigned our urethane pit mount 2 years ago and also reformulated the urethane so it will bend like a willow tree in a wind storm. Our old mount was strong but like an oak it would snap if bent too far.If anyone would like to try one free just call us,E-mail,etc. Jim
                  Re: Pit mounts
                  I like the original bruns mounts 4 piece. I have found the one piece is too stiff. I like flexabilty. I believe the stiffer the mounts are the harder the shaker assy. has to work. Thus causing more wear and tear on assy.
                    Re: Pit mounts
                    I agree the old style black mounts are the easiest to change. I use a keps-it nut instead of the original acorn lock nut, makes it easier to undo if the mount comes apart.
                      Re: Pit mounts
                      Hey Bowl Techers.
                      Does Brunswick still sell the TORSIONAL pit mounts???
                      About 8 years ago they gave me 2 sets to try in a pair of lanes.
                      The rubber bushings inside the mounts were worn out after about a year and a half.
                      I tried to order just the rubber parts because the rest of the mounts were still good.
                      Good old Brunswick told me they only sold whole sets of torsional mounts and not individual parts for them.
                      Well needless to say they went in the trash!
                      Grambo
                        Re: Pit mounts
                        YUP! Good ole black mounts last long.Have seen those torsion ones in the book and...no thanks!Tried those green solid urethane mounts but not much luck here.Those short lil black jobbers work great!
                          Re: Pit mounts
                          Hey all,
                          We use the "green" mounts sold by QBC. Funny how we identify the urethane parts by color...heh
                          We did experiment with some home-made hard plastic shaker mounts that were capped with some type of rubbery material. The front mounts on the pin deck side seemed to work well, still have quite a few on the machines. The rear mounts ended up having a life span of about 3-4 weeks. Not very good, had to change them all back out again.
                          Go for the GREEN ones
                          Wookie
